bei der Installtion erhalte ich die nachfolgende Meldung in Schleife. Ich hatte vorher bereits eine Instanz von paperless-ngx laufen. Diese hatte ich vor der erneuten Installtion gestoppt.
Für sachdienliche Hinweise zur Lösung des Problems bin ich dankbar ;-).
Markus
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/inotify_simple.py", line 110, in add_watch
paperless-webserver-1 | return _libc_call(_libc.inotify_add_watch, self.fileno(), fsencode(path), mask)
paperless-webserver-1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/inotify_simple.py", line 39, in _libc_call
paperless-webserver-1 | raise OSError(errno, os.strerror(errno))
paperless-webserver-1 | PermissionError: [Errno 13] Permission denied
paperless-webserver-1 | 2024-06-14 12:16:30,042 WARN exited: consumer (exit status 1; not expected)
paperless-webserver-1 | 2024-06-14 12:16:31,044 INFO spawned: 'consumer' with pid 517
paperless-webserver-1 | 2024-06-14 12:16:32,046 INFO success: consumer entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
paperless-webserver-1 | [2024-06-14 14:16:34,393] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
paperless-webserver-1 | Traceback (most recent call last):
paperless-webserver-1 | File "/usr/src/paperless/src/manage.py", line 10, in <module>
paperless-webserver-1 | execute_from_command_line(sys.argv)
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/django/core/management/__init__.py", line 442, in execute_from_command_line
paperless-webserver-1 | utility.execute()
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/django/core/management/__init__.py", line 436, in execute
paperless-webserver-1 | self.fetch_command(subcommand).run_from_argv(self.argv)
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/django/core/management/base.py", line 412, in run_from_argv
paperless-webserver-1 | self.execute(*args, **cmd_options)
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/django/core/management/base.py", line 458, in execute
paperless-webserver-1 | output = self.handle(*args, **options)
paperless-webserver-1 | File "/usr/src/paperless/src/documents/management/commands/document_consumer.py", line 251, in handle
paperless-webserver-1 | self.handle_inotify(directory, recursive, options["testing"])
paperless-webserver-1 | File "/usr/src/paperless/src/documents/management/commands/document_consumer.py", line 297, in handle_inotify
paperless-webserver-1 | descriptor = inotify.add_watch_recursive(directory, inotify_flags)
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/inotifyrecursive/inotifyrecursive.py", line 116, in add_watch_recursive
paperless-webserver-1 | return self.__add_watch_recursive(path, mask, filter, name, -1, False)
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/inotifyrecursive/inotifyrecursive.py", line 90, in __add_watch_recursive
paperless-webserver-1 | self.__add_watch_recursive(entrypath, mask, filter, entry, wd)
paperless-webserver-1 | File "/usr/local/lib/python3.11/site-packages/inotifyrecursive/inotifyrecursive.py", line 79, in __add_watch_recursive
paperless-webserver-1 | wd = inotify_simple.INotify.add_watch(self, path, mask | flags.IGNORED | flags.CREATE | flags.MOVED_FROM | flags.MOVED_TO)
paperless-webserver-1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
