habe nachdem ich den export Befehl endlich erfolgreich abgeschickt habe meine docker-compose.yml nach paperless-ngx/docker/compose at dev · paperless-ngx/paperless-ngx · GitHub für docker-compose.sqlite-tika.yml angepasst.
Bekomme folgende Meldungen:
odman-compose version: 1.0.6
[‚podman‘, ‚–version‘, ‚‘]
using podman version: 4.9.3
File „/usr/bin/podman-compose“, line 33, in
sys.exit(load_entry_point(‚podman-compose==1.0.6‘, ‚console_scripts‘, ‚podman-compose‘)())
File „/usr/lib/python3/dist-packages/podman_compose.py“, line 2941, in main
podman_compose.run()
File „/usr/lib/python3/dist-packages/podman_compose.py“, line 1421, in run
self._parse_compose_file()
File „/usr/lib/python3/dist-packages/podman_compose.py“, line 1488, in _parse_compose_file
content = yaml.safe_load(f)
File „/usr/lib/python3/dist-packages/yaml/init.py“, line 125, in safe_load
return load(stream, SafeLoader)
File „/usr/lib/python3/dist-packages/yaml/init.py“, line 81, in load
return loader.get_single_data()
File „/usr/lib/python3/dist-packages/yaml/constructor.py“, line 49, in get_single_data
node = self.get_single_node()
File „/usr/lib/python3/dist-packages/yaml/composer.py“, line 36, in get_single_node
document = self.compose_document()
File „/usr/lib/python3/dist-packages/yaml/composer.py“, line 55, in compose_document
node = self.compose_node(None, None)
File „/usr/lib/python3/dist-packages/yaml/composer.py“, line 84, in compose_node
node = self.compose_mapping_node(anchor)
File „/usr/lib/python3/dist-packages/yaml/composer.py“, line 133, in compose_mapping_node
item_value = self.compose_node(node, item_key)
File „/usr/lib/python3/dist-packages/yaml/composer.py“, line 127, in compose_mapping_node
while not self.check_event(MappingEndEvent):
File „/usr/lib/python3/dist-packages/yaml/parser.py“, line 98, in check_event
self.current_event = self.state()
File „/usr/lib/python3/dist-packages/yaml/parser.py“, line 428, in parse_block_mapping_key
if self.check_token(KeyToken):
File „/usr/lib/python3/dist-packages/yaml/scanner.py“, line 116, in check_token
self.fetch_more_tokens()
File „/usr/lib/python3/dist-packages/yaml/scanner.py“, line 223, in fetch_more_tokens
return self.fetch_value()
File „/usr/lib/python3/dist-packages/yaml/scanner.py“, line 577, in fetch_value
raise ScannerError(None, None,
yaml.scanner.ScannerError: mapping values are not allowed here
in „/home/hkaufmann/Daten/DBank/paperless/docker-compose.yml“, line 56, column 29
Was ist verkehrt? Hier meine docker-compse.yml:
Muß die docker-compose.env auch angepasst werden? Wenn ja, wie?
