sudo docker-compose down
redis container gelöscht
paperless_redisdata gelöscht
Paperless-ngx neu aufgespielt. mit neuer docker-compose.yml mit der Version 2.10.2 (habe ich geändert in der Datei).
Es läuft nun importiert er woher auch immer ca. 550 Dateien. (???)
wenn ich nun parallel den sudo docker-compose exec -T webserver document_importer ../export laufen lasse, kommt diese Meldung…
Found existing user(s), this might indicate a non-empty installation
Found existing documents(s), this might indicate a non-empty installation
Checking the manifest
Database import failed
No version information present
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 89, in _execute
File "/usr/local/lib/python3.11/site-packages/psycopg/cursor.py", line 732, in execute
raise ex.with_traceback(None)
psycopg.errors.UniqueViolation: duplicate key value violates unique constraint "documents_document_checksum_75209391_uniq"
DETAIL: Key (checksum)=(2a1fc49ff408af80a470f09111f45355) already exists.
File "/usr/local/lib/python3.11/site-packages/django/core/management/__init__.py", line 442, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python3.11/site-packages/django/core/management/__init__.py", line 436, in execute
File "/usr/local/lib/python3.11/site-packages/django/core/management/base.py", line 412, in run_from_argv
File "/usr/local/lib/python3.11/site-packages/django/core/management/base.py", line 458, in execute
File "/usr/src/paperless/src/documents/management/commands/document_importer.py", line 268, in handle
self.load_data_to_database()
File "/usr/src/paperless/src/documents/management/commands/document_importer.py", line 222, in load_data_to_database
raise e
File "/usr/src/paperless/src/documents/management/commands/document_importer.py", line 203, in load_data_to_database
call_command("loaddata", manifest_path)
File "/usr/local/lib/python3.11/site-packages/django/core/management/__init__.py", line 194, in call_command
return command.execute(*args, **defaults)
File "/usr/local/lib/python3.11/site-packages/django/core/management/commands/loaddata.py", line 102, in handle
self.loaddata(fixture_labels)
File "/usr/local/lib/python3.11/site-packages/django/core/management/commands/loaddata.py", line 163, in loaddata
self.load_label(fixture_label)
File "/usr/local/lib/python3.11/site-packages/django/core/management/commands/loaddata.py", line 253, in load_label
if self.save_obj(obj):
File "/usr/local/lib/python3.11/site-packages/django/core/management/commands/loaddata.py", line 209, in save_obj
obj.save(using=self.using)
File "/usr/local/lib/python3.11/site-packages/django/core/serializers/base.py", line 288, in save
models.Model.save_base(self.object, using=using, raw=True, **kwargs)
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 877, in save_base
updated = self._save_table(
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 1020, in _save_table
results = self._do_insert(
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 1061, in _do_insert
return manager._insert(
File "/usr/local/lib/python3.11/site-packages/django/db/models/manager.py", line 87, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 1805, in _insert
return query.get_compiler(using=using).execute_sql(returning_fields)
File "/usr/local/lib/python3.11/site-packages/django/db/models/sql/compiler.py", line 1822, in execute_sql
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 67, in execute
return self._execute_with_wrappers(
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 80, in _execute_with_wrappers
return executor(sql, params, many, context)
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 84, in _execute
with self.db.wrap_database_errors:
File "/usr/local/lib/python3.11/site-packages/django/db/utils.py", line 91, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
django.db.utils.IntegrityError: Problem installing fixture '/usr/src/paperless/export/manifest.json': Could not load documents.Document(pk=276): duplicate key value violates unique constraint "documents_document_checksum_75209391_uniq"
Die Version von Paperless
die Version von der export datei
was auch immer diese Datei besagt
diese Dateien sind in dem export Ordner:
neben 4552 weiteren als .pdf/.webp/.jpg
