Dateiaufgaben Meldungen: "File not found"
KSS_20231101_16271968_000287.pdf: Cannot consume /usr/src/paperless/consume/KSS_20231101_16271968_000287.pdf: File not found.
Nach dem Import eines Dokumentes, das auch korrekt importiert ist, erhalte ich 10-12 x folgende Fehlerangabe bei den Dateiaufgaben ?
Ist das so korrekt ?
Hast du zufällig den Papierkorb für den Scaninput-Ordner aktiviert?
Das siehst du in den Einstellungen des freigegebenen Ordners.
nein-nicht aktiviert
[2023-11-25 11:37:51,933] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:37:55,496] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:37:59,163] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:02,739] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:06,312] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:09,896] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:10,448] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:12,151] [INFO] [paperless.consumer] Consuming KSS_20231101_16270256_000285.pdf
[2023-11-25 11:38:12,158] [DEBUG] [paperless.consumer] Detected mime type: application/pdf
[2023-11-25 11:38:12,181] [DEBUG] [paperless.consumer] Parser: RasterisedDocumentParser
[2023-11-25 11:38:12,190] [DEBUG] [paperless.consumer] Parsing KSS_20231101_16270256_000285.pdf...
[2023-11-25 11:38:13,469] [DEBUG] [paperless.parsing.tesseract] Calling OCRmyPDF with args: {'input_file': PosixPath('/tmp/paperless/paperless-ngxhz08t6bx/KSS_20231101_16270256_000285.pdf'), 'output_file': PosixPath('/tmp/paperless/paperless-za2m99ua/archive.pdf'), 'use_threads': True, 'jobs': 4, 'language': 'deu', 'output_type': 'pdfa', 'progress_bar': False, 'skip_text': True, 'clean': True, 'deskew': True, 'rotate_pages': True, 'rotate_pages_threshold': 12.0, 'sidecar': PosixPath('/tmp/paperless/paperless-za2m99ua/sidecar.txt')}
[2023-11-25 11:38:14,211] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:14,500] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:17,847] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:18,182] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:20,595] [DEBUG] [paperless.parsing.tesseract] Incomplete sidecar file: discarding.
[2023-11-25 11:38:20,811] [DEBUG] [paperless.consumer] Generating thumbnail for KSS_20231101_16270256_000285.pdf...
[2023-11-25 11:38:20,823] [DEBUG] [paperless.parsing] Execute: convert -density 300 -scale 500x5000> -alpha remove -strip -auto-orient /tmp/paperless/paperless-za2m99ua/archive.pdf[0] /tmp/paperless/paperless-za2m99ua/convert.webp
[2023-11-25 11:38:21,879] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:22,159] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:26,186] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:26,461] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:30,313] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:30,602] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:34,323] [DEBUG] [paperless.classifier] Document classification model does not exist (yet), not performing automatic matching.
[2023-11-25 11:38:34,331] [DEBUG] [paperless.consumer] Saving record to database
[2023-11-25 11:38:34,332] [DEBUG] [paperless.consumer] Creation date from parse_date: 2023-08-15 00:00:00+02:00
[2023-11-25 11:38:34,379] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf to the task queue.
[2023-11-25 11:38:34,634] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:37,027] [DEBUG] [paperless.consumer] Deleting file /tmp/paperless/paperless-ngxhz08t6bx/KSS_20231101_16270256_000285.pdf
[2023-11-25 11:38:37,134] [DEBUG] [paperless.parsing.tesseract] Deleting directory /tmp/paperless/paperless-za2m99ua
[2023-11-25 11:38:37,136] [INFO] [paperless.consumer] Document 2023-08-15 KSS_20231101_16270256_000285 consumption finished
[2023-11-25 11:38:38,453] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:41,882] [ERROR] [paperless.consumer] Cannot consume /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf: File not found.
[2023-11-25 11:38:42,063] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:43,507] [ERROR] [paperless.consumer] Cannot consume /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf: File not found.
[2023-11-25 11:38:44,830] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:44,945] [ERROR] [paperless.consumer] Cannot consume /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf: File not found.
[2023-11-25 11:38:47,248] [ERROR] [paperless.consumer] Cannot consume /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf: File not found.
[2023-11-25 11:38:47,585] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:48,390] [ERROR] [paperless.consumer] Cannot consume /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf: File not found.
[2023-11-25 11:38:50,665] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:52,066] [ERROR] [paperless.consumer] Cannot consume /usr/src/paperless/consume/KSS_20231101_16270256_000285.pdf: File not found.
[2023-11-25 11:38:54,277] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
[2023-11-25 11:38:57,857] [INFO] [paperless.management.consumer] Using inotify to watch directory for changes: /usr/src/paperless/consume
OK- selber gelöst.
Ich hatte bei der Erstellung des scaninput Ordner einen Ordner umbenannt, der leer nicht mehr benötigt wurde und Papierkorb entfernt . Im Fileverzeichnis existierte aber noch der recycle Ordner. Gelöscht und alles bestens !
Danke für deine Rückmeldung! Also war es doch der Papierkorb, der noch im Hintergrund aktiv war :wink:
