Features / Enhancements
docker-compose(deps): bump nginx from 1.31.3-alpine to 1.31.5-alpine in /docker/compose @dependabot[bot] (#13909)
docker-compose(deps): Bump greenmail/standalone from 2.1.11 to 2.1.13 in /docker/compose @dependabot[bot] (#13907)
Bug Fixes
Fix: use the header loading indicator on tasks page @shamoon (#13949)
Fix: fix load sidebar size animating @shamoon (#13947)
Fix: wrap long words without spaces in dropdowns @shamoon (#13945)
Fix: tweak tool calling localzation prompt @shamoon (#13943)
Fix: skip vector store document id filter for unrestricted chat users @stumpylog (#13937)
Fix: adopt the request stream when pinning an outbound host @ThomasSteinbach (#13927)
Fix: ensure apply ai suggestions always runs after document created @shamoon (#13940)
Fix: Handle failures when enqueuing files for consumption @stumpylog (#13935)
Fix: Handle Celery mail task chord errors @stumpylog (#13936)
Fix/chore: refactor some signal-backed conversion technical debt @shamoon (#13902)
Fix: fix slim sidebar saved view dragging appearance @shamoon (#13906)
Fix: use signal-backed queries input in CF dropdown to reflect changes immediately under zoneless @shamoon (#13901)
Fix: use root doc metadata for filename generation @shamoon (#13893)
Fix: some css cleanup @shamoon (#13891)
Dependencies
7 changes
Chore(deps): Bump the uv group across 1 directory with 2 updates @dependabot[bot] (#13958)
Chore(deps-dev): Bump postcss-selector-parser from 6.1.2 to 6.1.4 in /src/paperless_mail/templates in the npm_and_yarn group across 1 directory @dependabot[bot] (#13905)
Chore(deps): Bump nltk from 3.10.0 to 3.10.3 in the data-nlp-search group across 1 directory @dependabot[bot] (#13917)
Chore(deps): Bump the frontend-angular-dependencies group across 1 directory with 14 updates @dependabot[bot] (#13915)
Chore(deps): Bump djangorestframework from 3.17.1 to 3.17.2 in the uv group across 1 directory @dependabot[bot] (#13904)
All App Changes
22 changes
Security: validate remote OCR endpoint @stumpylog (#13897)
Security: Minor additional hardening @stumpylog (#13898)
Chore: consolidate pickle hmac signing @shamoon (#13899)
View it on GitHub:
Zusammengefasst
Das Release 3.1.3 ist vor allem ein Wartungs- und Bugfix-Release. Es bringt:
- mehrere Fehlerbehebungen im Frontend und bei Hintergrundprozessen
- kleine Sicherheitsverbesserungen
- aktualisierte Abhängigkeiten und Container-Komponenten
- keine großen neuen Funktionen, eher Stabilitäts- und Verbesserungsarbeiten
Wichtigste Punkte
1. Fehlerbehebungen
- Probleme in der Oberfläche wurden behoben, z. B.:
- Ladeanzeige auf der Aufgaben-Seite
- Animationen der Sidebar
- Darstellung sehr langer Wörter in Dropdowns
- Drag-and-drop-Ansicht gespeicherter Ansichten
- Verbesserungen bei Dokumentenverarbeitung:
- Fehler beim Einreihen von Dateien zur Verarbeitung
- Fehler bei E-Mail-/Celery-Aufgaben
- KI-Vorschläge werden zuverlässiger nach dem Erstellen eines Dokuments angewendet
- korrektere Dateinamen-Erzeugung anhand der Metadaten des Hauptdokuments
2. Sicherheitsverbesserungen
- Remote-OCR-Endpunkte werden jetzt geprüft
- zusätzliche kleine Härtungen zur Absicherung des Systems
3. Abhängigkeiten aktualisiert
- Updates für u. a.:
- nginx
- greenmail
- nltk
- Django REST Framework
- mehrere Angular-Frontend-Abhängigkeiten
Fazit
Version 3.1.3 ist ein stabiles Wartungsupdate mit Bugfixes, kleineren Sicherheitsverbesserungen und aktualisierten Abhängigkeiten. Für Nutzerinnen und Nutzer vor allem relevant sind die verbesserten UI-Fehler, die robustere Dokumentenverarbeitung und die zusätzlichen Sicherheitsprüfungen.
