Klar, in das Logfile könnte man auch schauen
Fehlermeldungen erscheinen auf den ersten Blick nicht. Auch einen anderen Browser habe ich bereits getestet, das Verhalten ist in Edge sowie Firefox identisch.
[2024-11-23 09:26:25,169] [DEBUG] [paperless.tasks] Skipping plugin CollatePlugin
[2024-11-23 09:26:25,169] [DEBUG] [paperless.tasks] Executing plugin BarcodePlugin
[2024-11-23 09:26:25,169] [DEBUG] [paperless.barcodes] Scanning for barcodes using PYZBAR
[2024-11-23 09:26:25,171] [DEBUG] [paperless.barcodes] PDF has 1 pages
[2024-11-23 09:26:25,171] [DEBUG] [paperless.barcodes] Processing page 0
[2024-11-23 09:26:25,320] [DEBUG] [paperless.barcodes] Image is at /tmp/paperless/tmpr6tkjdc5/barcoder2ufmdnr/39e1bcf1-466b-4f8e-9781-456f781ecd69-1.ppm
[2024-11-23 09:26:25,546] [INFO] [paperless.tasks] BarcodePlugin completed with no message
[2024-11-23 09:26:25,547] [DEBUG] [paperless.tasks] Executing plugin WorkflowTriggerPlugin
[2024-11-23 09:26:25,585] [INFO] [paperless.matching] Document did not match Workflow: Import
[2024-11-23 09:26:25,585] [DEBUG] [paperless.matching] ("Document source ApiUpload not in ['ConsumeFolder']",)
[2024-11-23 09:26:25,585] [INFO] [paperless.tasks] WorkflowTriggerPlugin completed with:
[2024-11-23 09:26:25,585] [DEBUG] [paperless.tasks] Executing plugin ConsumeTaskPlugin
[2024-11-23 09:26:25,593] [INFO] [paperless.consumer] Consuming HRM.pdf
[2024-11-23 09:26:25,594] [DEBUG] [paperless.consumer] Detected mime type: application/pdf
[2024-11-23 09:26:25,602] [DEBUG] [paperless.consumer] Parser: RasterisedDocumentParser
[2024-11-23 09:26:25,605] [DEBUG] [paperless.consumer] Parsing HRM.pdf...
[2024-11-23 09:26:25,617] [INFO] [paperless.parsing.tesseract] pdftotext exited 0
[2024-11-23 09:26:25,777] [DEBUG] [paperless.parsing.tesseract] Calling OCRmyPDF with args: {'input_file': PosixPath('/tmp/paperless/paperless-ngxzudhee20/HRM.pdf'), 'output_file': PosixPath('/tmp/paperless/paperless-ek96mn7h/archive.pdf'), 'use_threads': True, 'jobs': 4, 'language': 'deu', 'output_type': 'pdf', 'progress_bar': False, 'skip_text': True, 'clean': True, 'deskew': True, 'rotate_pages': True, 'rotate_pages_threshold': 12.0, 'pages': '1-1'}
[2024-11-23 09:26:25,915] [WARNING] [ocrmypdf._pipeline] This PDF is marked as a Tagged PDF. This often indicates that the PDF was generated from an office document and does not need OCR. PDF pages processed by OCRmyPDF may not be tagged correctly.
[2024-11-23 09:26:25,916] [INFO] [ocrmypdf._pipeline] skipping all processing on this page
[2024-11-23 09:26:25,923] [INFO] [ocrmypdf._pipelines.ocr] Postprocessing...
[2024-11-23 09:26:25,994] [INFO] [ocrmypdf._pipeline] Image optimization ratio: 1.00 savings: 0.0%
[2024-11-23 09:26:25,995] [INFO] [ocrmypdf._pipeline] Total file size ratio: 1.03 savings: 2.9%
[2024-11-23 09:26:26,023] [INFO] [paperless.parsing.tesseract] pdftotext exited 0
[2024-11-23 09:26:26,024] [DEBUG] [paperless.consumer] Generating thumbnail for HRM.pdf...
[2024-11-23 09:26:26,027] [DEBUG] [paperless.parsing] Execute: convert -density 300 -scale 500x5000> -alpha remove -strip -auto-orient -define pdf:use-cropbox=true /tmp/paperless/paperless-ek96mn7h/archive.pdf[0] /tmp/paperless/paperless-ek96mn7h/convert.webp
[2024-11-23 09:26:26,898] [INFO] [paperless.parsing] convert exited 0
[2024-11-23 09:26:26,923] [DEBUG] [paperless.consumer] Saving record to database
[2024-11-23 09:26:26,924] [DEBUG] [paperless.consumer] Creation date from st_mtime: 2024-11-23 09:26:25+01:00
[2024-11-23 09:26:27,060] [INFO] [paperless.matching] Document matched WorkflowTrigger 1 from Workflow: Benutzer xxx
[2024-11-23 09:26:27,060] [INFO] [paperless.handlers] Applying WorkflowAction 1 from Workflow: Benutzer xxx
[2024-11-23 09:26:27,125] [DEBUG] [paperless.consumer] Deleting file /tmp/paperless/paperless-ngxzudhee20/HRM.pdf
[2024-11-23 09:26:27,160] [DEBUG] [paperless.parsing.tesseract] Deleting directory /tmp/paperless/paperless-ek96mn7h
[2024-11-23 09:26:27,161] [INFO] [paperless.consumer] Document 2024-11-23 HRM consumption finished
[2024-11-23 09:26:27,166] [INFO] [paperless.tasks] ConsumeTaskPlugin completed with: Success. New document id 639 created
