Nach einem Neustart der Maschine auf der der/die paperless-container laufen, startet der paperless NGX container nicht mehr.
REDIS und DB-container scheinen korrekt zu starten (werden in Portainer als running deklariert)
Das Log zeigt folgende EInträge:
[init-start] paperless-ngx docker container starting…
[init-start] paperless-ngx docker container starting init as root
[env-init] Checking for environment from files
[env-init] No *_FILE environment found
[init-redis-wait] Waiting for Redis to report ready
[init-tesseract-langs] Checking if additional teseract languages needed
[init-db-wait] Waiting for PostgreSQL to start…
[init-tesseract-langs] No additional installs requested
[init-user] No UID changes for paperless
[init-user] No GID changes for paperless
[init-folders] Running with root privileges, adjusting directories and permissions
db:5432 - no response
[init-db-wait] Attempt 1 failed! Trying again in 1 seconds…
Waiting for Redis…
Redis ping #0 failed.
Error: Error -3 connecting to broker:6379. Temporary failure in name resolution..
Waiting 5s
[init-db-wait] Attempt 2 failed! Trying again in 2 seconds…
[init-db-wait] Attempt 3 failed! Trying again in 3 seconds…
Redis ping #1 failed.
Waiting 5s
[init-db-wait] Attempt 4 failed! Trying again in 4 seconds…
[init-db-wait] Attempt 5 failed! Trying again in 5 seconds…
Redis ping #2 failed.
Waiting 5s
[init-db-wait] Attempt 6 failed! Trying again in 6 seconds…
Redis ping #3 failed.
Waiting 5s
Redis ping #4 failed.
Waiting 5s
[init-db-wait] Attempt 7 failed! Trying again in 7 seconds…
Failed to connect to redis using environment variable PAPERLESS_REDIS.
s6-rc: warning: unable to start service init-wait-for-redis: command exited 1
[init-db-wait] Attempt 8 failed! Trying again in 8 seconds…
[init-db-wait] Attempt 9 failed! Trying again in 9 seconds…
Die Variable verweist auf redis://broker:6379
Hast du nur die Container neu gestartet oder auch Aktualisierungen vorgenommen?
Wenn du eine Synology hast, ist die Firewall aktiviert?
Wenn ja, deaktivieren und Paperless neu starten
s6-rc Fehler bedeutet normalerweise dass die Berechtigungen nicht mehr passen, der Benutzer hat nicht die Berechtigung auf ein Laufwerk bzw. Ordner zu schreiben
