Guten Morgen zusammen,
es ist eine neue Version von paperless-ngx verfügbar: 2.11.
Wichtige Änderungen für gotenberg-Nutzer
Auf den ersten Blick fällt auf: Gotenberg, der Service, der es ermöglicht, Office-Dateien zu konsumieren, wird nun in der Version 8 unterstützt.
Wie ihr diese nutzt, erkläre ich in diesem separaten Beitrag und natürlich auch zeitnah ausführlich in der paperless-ngx Masterclass.
Release Notes:
paperless-ngx 2.11.0
Breaking Changes
- Feature: Upgrade Gotenberg to v8 @stumpylog (#7094)
Features
- Enhancement: disable add split button when approrpriate @shamoon (#7215)
- Enhancement: wrapping of saved view fields d-n-d UI @shamoon (#7216)
- Enhancement: support custom field icontains filter for select type @shamoon (#7199)
- Feature: select custom field type @shamoon (#7167)
- Feature: automatic sso redirect @shamoon (#7168)
- Enhancement: show more columns in mail frontend admin @shamoon (#7158)
- Enhancement: use request user as owner of split / merge docs @shamoon (#7112)
- Enhancement: improve date parsing with accented characters @fdubuy (#7100)
- Feature: improve history display of object names etc @shamoon (#7102)
Bug Fixes
- Fix: include documents in trash for existing asn check @shamoon (#7189)
- Fix: include documents in trash in sanity check @shamoon (#7133)
- Fix: handle errors for trash actions and only show documents user can restore or delete @shamoon (#7119)
- Fix: dont include documents in trash in counts @shamoon (#7111)
- Fix: use temp dir for split / merge @shamoon (#7105)
Maintenance
- Chore: upgrade to DRF 3.15 @shamoon (#7134)
- Chore(deps): Bump docker/build-push-action from 5 to 6 in the actions group @dependabot (#7125)
- Chore: Ignores DRF 3.15.2 @stumpylog (#7122)
- Chore: show docker tag in UI for ci test builds @shamoon (#7083)
(Quelle: Release Paperless-ngx v2.11.0 · paperless-ngx/paperless-ngx · GitHub)
