Hallo Zusammen
Habe folgendes Problem, es werden weder über den scaninput noch direkt über Paperless Dateien importiert. Paperless erkennt zwar die Dateien diese werden jedoch nicht verarbeitet. Was kann ich da machen?
Aus meiner Sicht habe ich alles richtig Installiert die Rechte richtig vergeben.
Im Protokoll in Paperless sieht es dann so aus.
[2024-06-09 17:37:53,750] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/Test Datei.pdf to the task queue.
[2024-06-09 17:37:54,076] [ERROR] [paperless.handlers] Updating PaperlessTask failed
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 89, in _execute
File "/usr/local/lib/python3.11/site-packages/psycopg/cursor.py", line 732, in execute
raise ex.with_traceback(None)
psycopg.errors.IndexCorrupted: index "django_cele_task_na_08aec9_idx" contains unexpected zero page at block 0
HINT: Please REINDEX it.
File "/usr/local/lib/python3.11/site-packages/celery/app/trace.py", line 443, in trace_task
task.backend.store_result(
File "/usr/local/lib/python3.11/site-packages/celery/backends/base.py", line 526, in store_result
self._store_result(task_id, result, state, traceback,
File "/usr/local/lib/python3.11/site-packages/django_celery_results/backends/database.py", line 147, in _store_result
self.TaskModel._default_manager.store_result(**task_props)
File "/usr/local/lib/python3.11/site-packages/django_celery_results/managers.py", line 42, in _inner
return fun(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/django_celery_results/managers.py", line 164, in store_result
obj, created = self.using(using).get_or_create(task_id=task_id,
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 916, in get_or_create
return self.get(**kwargs), False
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 633, in get
num = len(clone)
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 380, in __len__
self._fetch_all()
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 1881, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 91, in __iter__
results = compiler.execute_sql(
File "/usr/local/lib/python3.11/site-packages/django/db/models/sql/compiler.py", line 1562, in execute_sql
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 67, in execute
return self._execute_with_wrappers(
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 80, in _execute_with_wrappers
return executor(sql, params, many, context)
File "/usr/local/lib/python3.11/site-packages/django/db/backends/utils.py", line 84, in _execute
with self.db.wrap_database_errors:
File "/usr/local/lib/python3.11/site-packages/django/db/utils.py", line 91, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
django.db.utils.InternalError: index "django_cele_task_na_08aec9_idx" contains unexpected zero page at block 0
During handling of the above exception, another exception occurred:
psycopg.errors.NotNullViolation: null value in column "status" of relation "documents_paperlesstask" violates not-null constraint
DETAIL: Failing row contains (99877, 5cf52129-ccd6-4b1c-be8e-5f9a3ae2fe34, f, 2024-06-09 15:37:53.752024+00, 2024-06-09 15:37:54.074761+00, 2024-06-09 15:37:53.997593+00, null, null, Test Datei.pdf, documents.tasks.consume_file).
File "/usr/src/paperless/src/documents/signals/handlers.py", line 852, in task_postrun_handler
task_instance.save()
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 814, in save
self.save_base(
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 877, in save_base
updated = self._save_table(
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 990, in _save_table
updated = self._do_update(
File "/usr/local/lib/python3.11/site-packages/django/db/models/base.py", line 1054, in _do_update
return filtered._update(values) > 0
File "/usr/local/lib/python3.11/site-packages/django/db/models/query.py", line 1231, in _update
return query.get_compiler(self.db).execute_sql(CURSOR)
File "/usr/local/lib/python3.11/site-packages/django/db/models/sql/compiler.py", line 1984, in execute_sql
cursor = super().execute_sql(result_type)
django.db.utils.IntegrityError: null value in column "status" of relation "documents_paperlesstask" violates not-null constraint
Besten Dank für die Hilfe.
