im paperless Protokoll steht das:
[2024-09-30 19:05:02,123] [DEBUG] [paperless.classifier] Gathering data from database…
[2024-09-30 19:05:02,337] [INFO] [paperless.classifier] No updates since last training
[2024-09-30 19:05:02,349] [DEBUG] [paperless.tasks] Training data unchanged.
[2024-09-30 19:08:47,426] [DEBUG] [paperless.management.consumer] Waiting for file /usr/src/paperless/consume/Nun der Tipp.docx to remain unmodified
[2024-09-30 19:08:52,683] [INFO] [paperless.management.consumer] Adding /usr/src/paperless/consume/Nun der Tipp.docx to the task queue.
[2024-09-30 19:08:52,850] [DEBUG] [paperless.tasks] Skipping plugin CollatePlugin
[2024-09-30 19:08:52,857] [DEBUG] [paperless.tasks] Skipping plugin BarcodePlugin
[2024-09-30 19:08:52,863] [DEBUG] [paperless.tasks] Executing plugin WorkflowTriggerPlugin
[2024-09-30 19:08:52,872] [INFO] [paperless.tasks] WorkflowTriggerPlugin completed with:
[2024-09-30 19:08:52,878] [DEBUG] [paperless.tasks] Executing plugin ConsumeTaskPlugin
[2024-09-30 19:08:52,951] [INFO] [paperless.consumer] Consuming Nun der Tipp.docx
[2024-09-30 19:08:52,966] [DEBUG] [paperless.consumer] Detected mime type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
[2024-09-30 19:08:53,181] [DEBUG] [paperless.consumer] Parser: TikaDocumentParser
[2024-09-30 19:08:53,192] [DEBUG] [paperless.consumer] Parsing Nun der Tipp.docx…
[2024-09-30 19:08:53,198] [INFO] [paperless.parsing.tika] Sending /tmp/paperless/paperless-ngxyyihl_ph/Nun der Tipp.docx to Tika server
[2024-09-30 19:08:53,293] [INFO] [paperless.parsing.tika] Converting /tmp/paperless/paperless-ngxyyihl_ph/Nun der Tipp.docx to PDF as /tmp/paperless/paperless-6bl1csuq/convert.pdf
[2024-09-30 19:08:53,598] [DEBUG] [paperless.consumer] Generating thumbnail for Nun der Tipp.docx…
[2024-09-30 19:08:53,609] [DEBUG] [paperless.parsing] Execute: convert -density 300 -scale 500x5000> -alpha remove -strip -auto-orient -define pdf:use-cropbox=true /tmp/paperless/paperless-6bl1csuq/convert.pdf[0] /tmp/paperless/paperless-6bl1csuq/convert.webp
[2024-09-30 19:08:54,609] [INFO] [paperless.parsing] convert exited 0
[2024-09-30 19:08:56,479] [DEBUG] [paperless.consumer] Saving record to database
[2024-09-30 19:08:56,484] [DEBUG] [paperless.consumer] Creation date from parse_date: 2024-09-30 19:07:00+00:00
[2024-09-30 19:08:57,189] [INFO] [paperless.handlers] Assigning document type Rechnung to 2024-09-30 Nun der Tipp
[2024-09-30 19:08:57,811] [DEBUG] [paperless.consumer] Deleting file /tmp/paperless/paperless-ngxyyihl_ph/Nun der Tipp.docx
[2024-09-30 19:08:57,841] [DEBUG] [paperless.parsing.tika] Deleting directory /tmp/paperless/paperless-6bl1csuq
[2024-09-30 19:08:57,847] [INFO] [paperless.consumer] Document 2024-09-30 Nun der Tipp consumption finished
[2024-09-30 19:08:57,861] [INFO] [paperless.tasks] ConsumeTaskPlugin completed with: Success. New document id 103 c
